Message 11 of 58
Re: Digital Voice and Reduced Broadband Speeed
I ended up leaving BT
Message 12 of 58
Who did you move to? I assume you're still on g.fast with your new ISP
Message 13 of 58
I moved to 4th Utility - the only fibre provider for my address
Message 14 of 58
Yes I have just had a mesg concerning Digital switch over and they are telling me my BB speed will be half it currently is. I'm not in a contract.
I'm waiting to speak to them as of course there is a long queue, but like you I'll drop my Landline as it isn't used, but not my speed.
Message 15 of 58
I've spoken to BT twice on this:
call 1 ) was told nothing would change with my broadband, I mentioned gfast and I don't think the rep understood what it was
call 2) the rep understood what was happening and cancelled the order. So for the time being my gfast connection will stay as it is
I'm now trying to decide whether to go to cerberusnetworks or filesanctuary to maintain my gfast connection
Message 16 of 58
will they also not be able to supply the gfast speed in 2027?
Message 17 of 58
I've been doing a bit of digging.  You may find this article interesting:
https://www.ispreview.co.uk/index.php/2026/05/bt-set-to-move-g-fast-uk-broadband-customers-to-sogea-...
Message 18 of 58
"say our sources" with contract ending in a month and they cant even acknowledge I was even on gfast i dont hold dmuch hope for this... i will no doubt be in another extortionate contract by then, that article was in May?
Message 19 of 58
From reading some threads on the EE forum, it seems BT/EE won't support g.fast or sogfast from January because they're decommissioning the Public Switched Telephone Network (PSTN) service on 31/01/27 and none of their (BT or EE) routers will support both sogfast and their new digital voice product, so they're moving everyone to SoGEA.
I'm moving to file sanctuary so I can ensure I continue to get sogfast
Message 20 of 58
Then you might want to take a look at this:
https://broadbandchecker.filesanctuary.net/
I wish you luck but I've just tried half a dozen family addresses, up and down the country.  Not one of them has SOGFAST available.
