Message 1 of 4
Digital Voice
I am about to use the 'Call Divert' function for the first time to connect to my mobile as I will be unavailable for a couple of days. The setup is straight forward but I can't find any instructions as to how you cancel/turn off the divert function on the DV handset when you no longer require it.
Can anybody help? it's probably something simple & obvious🙄
Thx in advance
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: Digital Voice
Message 3 of 4
Re: Digital Voice
Hi @Lenjam
On my DV phone with Alexa it is very simple:
Hitting direction left on the phone, it should take you to the Call Diversion menu.
Choose the Edit button (right hand side)  and simply choose Cancel divert.
Message 4 of 4
Re: Digital Voice
Thx Vet,
Simples & Obvious 🙄
