Message 1 of 5
Digital Voice
I use a BT Smart Hub 2 which has a Digital Voice slot to plug in a phone. Can I just plug in my corded landline phone and use it for Digital Voice. I have been a customer of BT for many years and want to avoid unnecessary expense. My Broadband runs on copper wires which is totally acceptable to me.
4 REPLIES 4
Message 2 of 5
Re: Digital Voice
yes it should work just fine
Message 3 of 5
Re: Digital Voice
Thank you so much for your prompt, and welcome, reply. I can breathe again. Many thanks.
Message 4 of 5
Re: Digital Voice
The phone port on the SH2 will only work if you have been migrated onto Digital Voice , if your voice service is still PSTN then you cannot use the SH2 for telephony yet .
There is no unnecessary expense, the cost is the same for telephony regardless of it being on DV or PSTN .
Message 5 of 5
Re: Digital Voice
Thank you for the excellent information and advice. Now I know exactly what to do when I am migrated. Brilliant.
