Message 11 of 15
Re: Digital changeover
Thanks for confirming @Ian1157. Since the Guide only mentioned your changeover was delayed and didn’t raise the issue about the texts, and you're still receiving reminders despite arranging to switch to EE, I’d recommend reaching back out to the team. They can check why these messages are still being sent and make sure everything is updated correctly on your account.
Debbie
Message 12 of 15
Thanks. None of the options that appear via that number appear to relate to what my issue is I.e. digital changeover.
Message 13 of 15
Just an update here - I’ve spoken again to one of the Guides. Very helpful but still couldn’t  explain why I’m receiving the texts. It remains a mystery!
Message 14 of 15
Thanks for the update @Ian1157.
I'm sorry we couldn't help you get this resolved on the community. It’s frustrating when things don’t go as expected, but fingers crossed, your digital changeover will go through smoothly soon.
Debbie
Message 15 of 15
Thanks for your help.
