Message 21 of 26
Re: Digital phone interface with mobile phones
Many thanks for your reply
steve b
Message 22 of 26
Are all the Sky mobiles that fail to connect all being used in the same geographical area or are they from different parts of the country?
Message 23 of 26
All in the west midlands
steve b
Message 24 of 26
Hmm, do you have any contacts in a different part of the country that use Sky mobile and could make a test call to you?
Anonymous
Not applicable
Message 25 of 26
@imjollywrote:
as I already posted I have DV and use SKY mobile and have no problems with calls
Indeed, which is why I suggested that someone like you would be a good test of the OP's DV. If you were to try calling him & couldn't get through it would point to an issue with his DV. If you could get through it would point to something peculiar to those Sky SIMS or maybe the local mast.
Message 26 of 26
Many thanks 😊
