Message 1 of 11
Landline problems with Truecall
Until recently my landline was working perfectly with a Truecall Call Blocker Unit. However, over the last few months the Truecall unit has started having problems detecting the caller ID, typically saying that the last call arrived without caller ID. However my Panasonic telephone that's connected to the Truecall unit detects caller ID okay every time.
So I suspected a faulty unit. Truecall, to their credit, have now sent me two replacement Truecall units, and also a replacement memory card for the unit, but still the same fault. They suspect a problem with my landline or the Caller ID setup at the exchange.
So I've run the automated tests (text PHONE to 61998), but no problems found. Could this be caused by a fault on my line? Has anyone come across a similar problem?
My setup is FTTP broadband via an ONT unit, but a standard copper landline.
10 REPLIES 10
Message 2 of 11
Re: Landline problems with Truecall
@tarbat
Possibly a faulty port on the exchange line card, or a poor quality line, either of which could be reducing the lever of the CLI signalling tones which are sent just before the first ringing current.
I am surprised that being on FTTP, you have not been moved over to BT Digital Voice yet.
Message 3 of 11
Thanks for the quick reply. Yes, it's as if the ringing is happening before the Caller ID.
So how do I report this possible fault? The text replies I got after texting PHONE to 61998 were all about checking wifi.
I'd love to be switched over the Digital Voice, but I though rollout has been postponed? Can I request to be switched?
Message 4 of 11
Its a bit of a tricky fault, but changing the equipment number in the exchange may fix the problem. Getting BT to do that may be a problem, but a moderator may be able to help.
The DV rollout still continues for those customers without any special services shown against their line. I am not sure if you can request it.
Its best if I ask a moderator to look at both issues.
Message 5 of 11
Hi @tarbat I'm sorry to see you're having issues with caller display as I appreciate this is casing issues with your Trucall equipment. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to get this looked into.
Neil
Message 6 of 11
Thankyou. Hopefully a moderator can help. I do struggle to think how I would explain this problem to a BT call handler.
Message 7 of 11
Just a thought, having searched the forums a bit more.
Could Call Protect be interfering with the Truecall unit? There are other posts about it affecting telephones that have Truecall built-in, but only on a Digital Voice service. I have all blacklisting options turned off on Call Protect.
So I wondered if Call Protect on a standard copper landline can interfere with a standalone Truecall unit?
Message 8 of 11
If it was, it would affect your Panasonic phones, as you would get no CLI if Call Protect was intercepting the call.
The CLI signal is a slow speed 1200 Baud FSK (Frequency Shift Keying) within the audio spectrum. If the signal level is low then the TrueCall unit would not be able to decode it. It possible that the Panasonic phones have a more sensitive decoder.
Message 9 of 11
This is still being investigated by Openreach, although they've just sent a text asking if it's now fixed.
This is what happens when an incoming call arrives "without caller display information from your network", but then gets detected as 6 individual, separate incoming calls that completely confuse the Truecall unit.
Any other thoughts on a likely cause?
https://www.youtube.com/watch?v=zvmP8h-9Jlw
Message 10 of 11
Hi @tarbat
Thanks for dealing with me on this case.
Glad to hear that after further investigation Openreach found an issue at the exchange level and it is now resolved.
Happy to help.
Cheers
Stuart
