Message 1 of 4
Digital switch - no hub sent
Hi
can anyone help me as I getting nowhere with BT.
My elderly mum does not have internet and doesn’t want it.  She had a letter saying she was being upgraded to digital but since that has happened her old line is terrible and when she phones out the other person can’t hear her.
I have rung BT twice now and they keep saying the line is ok and then closing the queries.
I am right in thinking they should have sent her some kind of hub ?  I have asked them but they say not and that it has been done at the exchange.  Her phone is still plugged into the old socket on the wall but to me that is still using the old copper wiring.
She has no other phone and is 90 so this is really urgent.
thanks
gill
3 REPLIES 3
Message 2 of 4
Re: Digital switch - no hub sent
Hi @mrshill
Welcome to the community.
I'd like to try and get you and your Mum some help with this. I'm going to send you a private message. Could you check your community message inbox and get back to me please?
Chris
Message 3 of 4
Thank you very much Chris .
Message 4 of 4
There is a way to convert people off the old , soon to be retired PSTN network without broadband to newer IP style telephony ( BT call their IP telephony Digital Voice ) , without the customer getting any new equipment at home …basically instead of any new equipment being provided at the customer end of the ‘line’ it’s provided at the exchange end  (it’s not just a BT router/hub at the exchange but the technical details are somewhat irrelevant , it’s not regular DV )
…the changes were in part so the customer doesn’t need local power and a broadband router at home  (obviously that’s susceptible to power outages ) , but a change the customer does  need to be aware of is the need to ring the full national number , even on ‘local’ calls , apart from that from the customer perspective nothing else is needed and it should be a seamless change .
If your mother has been connected to this transitional product , then any problems can be tested for (and detected) in the same way as the previous PSTN service , so calling and saying my line is faulty, BT testing it and deciding if the fault is detectable, is no different to previously, however it’s conceivable that the new interface is faulty but it’s unlikely…
if your mother had at some point in the past  had the normal ‘automatic gain’ setting changed to a fixed level (something done very occasionally when customers complained the volume was too low, usually it was their hearing that was impaired ) chances are this can’t be replicated with this new transitional product (and TBH without anyone without a hearing impairment would say it’s too loud if the automatic gain setting was changed to a fixed setting, it was so rare chances are it’s not going to be remembered as a thing that was occasionally used for ‘quiet’ lines .
If possible,  it may be wise to get someone else to try this to verify if the volume etc is acceptable for the average user , if it is , your mother may need something like an amplified handset .
