Message 1 of 3
Digital voice and extensions.
I'm getting Digital voice soon, and I would like to be prepared.
Currently my extensions  are connected by a  cable to my master  socket.
Is it right all I need to do is  to disconnect the two wires (of the extension cable) at position 2 and 5 from the inside part of the master socket.
Then connect these two wires into a BT extension socket such as a 2/3A, again at positions 2 and 5.
Then connect this socket either to the existing master socket or the digital voice  of the smart hub 2, by a extension/patch lead.
2 REPLIES 2
Message 2 of 3
Re: Digital voice and extensions.
Message 3 of 3
if you are getting digital voice with existing FTTC then your method will work but the phone cable needs to go from new phone socket to connection on back of hub - not back to master
if FTTP then you can connect socket on back of hub to phone socket in master
