Message 1 of 6
Digital voice back up BBU
I need a back up for digital voice phone when there’s a power cut.
are the BBU in stock now with bt.
my mobile signal EE is poor inside my house ,I have to go outside to get a signal,
I am a pensioner do I Qualify for a free BBU
5 REPLIES 5
Message 2 of 6
Re: Digital voice back up BBU
just being a pensioner does not qualify for BBU and you also have a mobile signal.  in emergency you can call 999 on mobile and use best mobile signal in your are which may not be EE
Message 3 of 6
How often do you get a power cut? If you get lots, then complain to your electricity supplier.
Do you have FTTC or FTTP?
If you have FTTP, then how close is the home hub to the ONT?
Message 4 of 6
Power cuts one or two times every month lately.only for a short period .last one messed up the settings of
my bt hub. Had to reset my bt digital  phone . SSE doing some work on monday
 cutting trees back, might  solve the issue.
I am on fttp , ONT is about  45cm from my hub
Message 5 of 6
As the two units are close together, then a mains UPS would probably be the best option, as you can plug up to four items which could include ONT, Home Hub, and possibly phone base unit.
Look on Amazon for
CYBERPOWER BR700ELCD-UK Line-Interactive UPS 700VA/420W AVR
GreenPower Energy Saving Technology LCD USB UK Outlet type, Black
About £90, so not much more that a single unit from BT which you would need two of.
Message 6 of 6
Thanks for that reply I will have a look at that
