Message 1 of 14
Digital voice cables
Hi all I'm still trying to get this digital voice set up but now need a male to male wire from green part of the smart hub 2 to the bt digital adapter do bt supply these please
13 REPLIES 13
Message 2 of 14
Re: Digital voice cables
@Rob3rts75
You do not connect those together, they are separate phone connections.
You can connect one phone to the back of the home hub 2, and another phone to the DV adapter phone socket.
Message 3 of 14
Doh, should have read properly.
Message 4 of 14
the DV adapter connects wireless using DECT to the SH2  no wiring required  just pair to SH2
Message 5 of 14
Done all the set up the phone says can't make or receive calls no Internet connection
Message 6 of 14
have you checked in hub manager the DV is active  your phone number is shown in hub manager and will show as active
if just moved to DV you may need to restart the SH2
Message 7 of 14
Hub manager is saying phone not configured after multiple restarts
Message 8 of 14
Then you don't have DV yet.
Message 9 of 14
How is it the phone isn't working because we should be on DV
Message 10 of 14
until your phone number in SH2 shows active you are not on DV
try phoning CS 03301234150 and see if they can help you get connected
