Message 1 of 3
Digital voice change to small unfiltered socket?
I have a master socket that is then extended to a further "fat" master type filtered socket with phone and broadband ports which my hub is plugged into. Now I'm on digital voice could I just swap that "fat" port for a thin simple unfiltered rj11 plate?
2 REPLIES 2
Message 2 of 3
Re: Digital voice change to small unfiltered socket?
Message 3 of 3
Yes, filters are no longer required with DV
