Message 11 of 14
Re: Digital voice upgrade to full fibre
the hub looks like capable of FTTP connection so no need for new hub.  The  fibre cable will attach to existing bracket then run down wall to CSP then new cable will run back up wall then through wall into attic room.  hopefully fitter will be happy to do that but check first
Message 12 of 14
I have my connection from pole to roof/eaves level but was able to get installer to then run cable under eaves and into my converted attic room where my CSP and ONT are installed. the CSP is the cigar shaped white box.  you can ask you never know as far neater job
ONT  + internal CSPONT + internal CSP
Message 13 of 14
Thank you for confirming. I know a lot more now about the process than when i just posted. Thanks.
Message 14 of 14
Wow so you got both csp and ont installed inside. I could do with that too but depends on my engineer. We will see. Thanks for all the info. Appreciate it.
