Message 1 of 3
Faulty handset?
We have 3 cordless handsets and one is not working - the other two are fine.can I replace just the faulty one?
2 REPLIES 2
Message 2 of 3
Re: Faulty handset?
yes   you will have to pair the new phone to your existing base  there will be instructions in manual on how to do that
Message 3 of 3
Re: Faulty handset?
Thankyou
