Message 1 of 6
Faulty BT8600 handset/base station?
I have a BT8600 twin handset DECT phone which, having switched to DV, is connected to my router. The 2nd handset is upstairs in my home office. All worked OK until I switched to DV; now, it seems that the 2nd phone doesn't maintain its connection to the main base station. Everything seems OK - the base/handset says it's registered, etc. - until someone rings. First of all, the ringtone keeps breaking up and, if I answer the call, it doesn't connect and the main base station continues ringing.
Is this somehow caused by DV or just a coincidence this started happening when I switched? The phone is probably 8 years old.
5 REPLIES 5
Message 2 of 6
Re: Faulty BT8600 handset/base station?
Message 3 of 6
It won't be caused directly by the switch to DV but may be due to moving the base station to a slightly different location.
Message 4 of 6
The base station itself is in exactly the same place and, as it's always been, it's connected (now to the router) using an extension lead but I can't see that this would make a difference to the phone upstairs.
Anonymous
Not applicable
Message 5 of 6
You could try switching the handsets to see if the fault moves or stays in the same location. That will tell you if it’s the handset or a range issue. As the SH2 is also a DECT base station it could possibly be interfering with the 8600 base. Unfortunately it can’t be turned off if that is the case.
Message 6 of 6
I have the same problem -did you ever get an answer that solved the problem please.
