Message 1 of 7
Frustration with ongoing fault -how to progress
I reported a fuzzy phone line which worsens after several minutes  and a very weak broadband signal.  Since then I feel like I am on a merry go round.
I have been struggling since 1/11/22 with a fault,  it reported fault outside and fix estimated 4th, then email 5th saying needed more time.  I heard nothing after that and attempted to phone and resorted to online chat which was a nightmare - in all I was on chat for over an hour.  I had the presence of mind to copy and paste chat!  Told another date then later another text message with another date and then this morning yet another text with another date, which pushes this into next week.
I am unable to speak with anyone and I have to sit close to hub to use laptop.
All I am aware of is that it is being dealt with by a  priority  team in Cardiff that you cannot speak, text or email.
Any guidance would be appreciated.
P.S I did check the main socket as requested via chat link.
6 REPLIES 6
Message 2 of 7
Re: Frustration with ongoing fault -how to progress
Did you try resetting the hub to see if that helped?  if you have digital voice have you gone to hub manager then phone number and then reset base?
Message 3 of 7
I don't have digital voice, and I believe the fault is outside property overhead or underground.
Thank you
Message 4 of 7
Hi @Jaytwotwo I'm sorry about the fault with your line and the delay getting this sorted. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to chase up Openreach for an update.
Neil
Message 5 of 7
Sadly I am in total disbelief - today they worked on the problem and I had an email saying my service should be back to normal. This was about 2pm.  This evening when receiving a call the fuzz and crackling was as bad as ever.
After two weeks still not resolved.
I can't report a fault because the other two are still open.
Message 6 of 7
Hi @Jaytwotwo,
I am sorry that this is still ongoing.
I will let @DavidM know that you were in touch today so he can look into it for you.
DanielS
Message 7 of 7
Just to update the phone was dreadful last night - today it seems fine, so fingers crossed.
Many thanks to you and David M
