Message 1 of 2
Heat loss spam calls
Hello,
I seem to be plagued by robotic calls from a Heat Loss team, usually up to a daily call now. Call protect and the Telephone Preference service don't seem to have made much of a difference.
Love any other ideas.
1 REPLY 1
Message 2 of 2
Re: Heat loss spam calls
@Caher
Both Call Protect and TPS will not help, you need a call blocking phone. You will never be able to block the calls manually, there are thousands of numbers. Only a whitelist of numbers will work.
The most effective phone is the BT4600 cordless. Its 100% effective in blocking scam callers, as it forces them to announce themselves, which they never do. It still allows people you have stored in the phone`s directory to get through right away.
https://www.bt.com/help/user-guides/phones/landline-phones/cordless-phones-with-answer-machine/bt460...
