Message 11 of 16
Re: Helping neighbour with no internet - landline only
A recent post detailed that PDPL and DV are not the same , the functionality of DV voicemail,  using on line menus or directly from the phone keypad to alter settings isn’t available on the PDPL version of voicemail, it’s  a basic ‘cut down’ telephone service never designed to be a forever service , only available to existing phone only customers and  a short term solution to these customers removal from PSTN but not practical to provide DV as they don’t have broadband , apparently you need to call to change settings or turn it off completely.
In this case the OP neighbour never had voicemail, so turning it off completely puts them back to the position they were in previously when on PSTN  , and seems the most appropriate action to take, especially if they way PDPL voicemail needs to be managed ( via calls to customer service )  is ‘unacceptable’ to the user .
TBH , if something is offered for free but isn’t to the users liking, but  the option remove it is available, it’s difficult to see the case for complaining about it , use it as it is , or turn it off seems a reasonable choice .
Message 12 of 16
The letter they were sent made it appear that they would have Voicemail after the "upgrade". This was tested and found to be working. There was no indication that any further action would be required to keep it working. Turning it off having enabled it sounds entirely unreasonable.
Message 13 of 16
Why is turning it off in these circumstances entirely unreasonable ? , if they way this free service needs to be managed is unacceptable to the user , then frankly you either use it as it is , accepting its ( from your point of view) limitations or turn it off …expecting anything else smacks of entitlement.
This comment ‘There was no indication that any further action would be required to keep it working’ makes no sense , no action is needed to keep it working ,  I dare say the reason why it was not taking new messages , if that was the problem, was because the existing messages had never been listened too and saved or deleted .
Message 14 of 16
Your reply does not make sense. The service was offered, was working, then turned off without warning.
Message 15 of 16
I dare say It was turned off because you called and complained about it.
Message 16 of 16
"In any case, you can't enable the service by dialling 1571."
I didn't say you could enable DV or its voicemail service using 1571. Of course you can't.
But once DV has been enabled you can change its settings (including no. of rings to voicemail) by keying in 1571 and then following the menus that are read out. Nothing to do with computers either.
