Message 1 of 2
How can I tell if I'm calling a BT mobile?
HI. My package incldes free calls to BT mobiles. Does anyone know how to identify if a mobile number is a BT number or not? TIA.
1 REPLY 1
Message 2 of 2
Re: How can I tell if I'm calling a BT mobile?
It’s impossible to tell just by looking at the number , numbers are portable and can be moved between different mobile companies, so even if a number were originally issued by BT , there is no way to know (without consulting the person who ‘owns’ the number ) if they are still using BT or have switched to another mobile company.
