Message 1 of 6
How do I replace a broadband socket, and have it moved after recent flooding?
After a recent flooding the socket is flooded, and needs replacement and moving, I don’t currently have a broadband service as moved out. Would BT do this ?
DL
5 REPLIES 5
Message 2 of 6
Re: How do I replace a broadband socket, and have it moved after recent flooding?
The master phone socket would be Openreach’s responsibility.  Openreach don’t deal directly with the public so, assuming you are a BT customer, you would need to phone it into customer support.  They will pass it on to Openreach.  If you are not a BT customer, you need to contact your ISP.
Any internal extension sockets are your responsibility.
Message 3 of 6
Thanks, I don’t have a contact with anyone at present, I was with sky.
Message 4 of 6
The OP  sates they don’t currently don’t have  a broadband service (and presumably no standalone telephone service either ) from BT , so this  has nothing to do with BT .
Openreach won’t be interested as it’s not a working ‘line’ , should you order service ( from whoever you choose to use , that’s probably not BT anyway )  , and assuming there is no Openreach FTTP available in your area , then the socket gets replaced or relocated as part of an installation or early life failure via whoever your chose as the service provider , them in effect them liaising with Openreach, but only when you have made an order for service, not before.
Message 5 of 6
Thank you
Message 6 of 6
May be just order a completely new service (and even fibre to the premises if that is available) as then everythnig will be installed again as it was when I mvoed from normal BT to fibre to the premises Community Fibre recently.
