Message 1 of 13
How do I turn off the Answering machine off at the base, in a non complicated way.
Can you instruct me how to turn off the Answering machine off at the base.  Step by step would be Appreciated Thanks
I find reading information leaflet to complicated to understand.
12 REPLIES 12
Message 2 of 13
Re: How do I turn off the Answering machine off at the base, in a non complicated way.
Perhaps if we knew the make and model we might be able to help
Tags (1)
Message 3 of 13
you need to provide more information about your phone and answering machine.  do you mean 1571?
Message 4 of 13
Bt Advance Z quad. Thanks
Message 5 of 13
Bt advance z
Message 6 of 13
Has not the phone's base  (main handset) just got an ON/Off button to turn the Answerphone part on and off? My BT Advance phone has, although admittedly not a 'Z' model.
Message 7 of 13
As @HHGTTG  suggested there should be an on/off switch on the main base unit to turn answer machine on/of
Message 8 of 13
From page 36 of the manual.
Switch the answer machine on or
off and set the answer mode
1. Select Menu, Answer Phone is
displayed, press Select.
2. Press until Answer mode is
highlighted, press Select.
3. Press Left or Right to select On
or Off then scroll down to set the
answer mode, press Left or Right to
highlight Ans. & Rec or Answer only
and then select Save. Answer
mode saved will be displayed and the current answer mode will be announced.
Not sure how that can be clarified further.
Anonymous
Not applicable
Message 9 of 13
@HHGTTG @imjolly
Unfortunately there's only an "On" switch... 😉
Message 10 of 13
@Anonymous
According to the instruction booklet I downloaded it said you press that to switch the answering machine on or off
