Message 1 of 7
I have 4 BT Digital voice handsets, only two of the handset's ring all connected to smart hub by wif
I have 4 BT Digital voice handsets, only two of the handsets' rings all connected to smart hub by Wi-Fi and show incoming call on display.
6 REPLIES 6
Message 2 of 7
Re: I have 4 BT Digital voice handsets, only two of the handset's ring all connected to smart hub by
your phones connect to the SH2 using DECT not wifi - this has been covered many times on the forum
Message 3 of 7
Thank you for that, unfortunately does not answer my problem
Message 4 of 7
@raymond1234  With respect, ask the question you actually wish to be answered. Some folks will look at your initial post and wonder what it is you’re asking.
Message 5 of 7
Thank You, I did think my question was clear, I have 4 handsets only two ring on incoming call, question is why?
Message 6 of 7
I suspect the 2 that don't ring have been accidentally configured not to. Check the settings.
Failing that, try de-registering them from the hub and re-register them.
Message 7 of 7
They could be faulty, they may have the ‘ringer’ set to ‘off’ , the batteries inside them may be  past it .
Try changing the battery, check the ringer settings , reset to factory settings and pair them to the hub again.
There is nothing special or magical about these phones , they are essentially no different to any other DECT cordless phone system.
