Message 1 of 5
In call Options not working
So my issue is this, since I swapped from Analog phone to IP phone, in call options for some services don't work, Like today I tried to call Shark for some parts says press option 2, yet it is not recognised. Yet I can call another service and it will work. Banks don't seem to work, Government services also seem to fail.
4 REPLIES 4
Message 2 of 5
Re: In call Options not working
Hi @TrebleTA
Welcome to the community. We'll do our best to help you.
Which phone handsets are you using?
Chris
Message 3 of 5
I'm going to guess you're using a DV adaptor? If so, plug your phone directly into the back of the hub and it should work. There is a firmware fix being rolled out that will resolve it eventually.
Message 4 of 5
I have BT plug to RJ11 cable converter going in to the hub, is that what you mean?
My phone is a Panasonic KX-TGJ422E
Message 5 of 5
@TrebleTA
Can you plug the phone directly into the back of the hub, without using the cable converter?
Ali
