Message 1 of 3
Info please
Not sure where to put this message?
My brother has been with BT for many years and moved home last year, the house he now lives in  he is wanting to replace the outer door, however it would appear the phone wire comes in through the door frame, if when he has the door replaced will BT charge to wire again? hope that makes sense.  Thanks Jules
2 REPLIES 2
Message 2 of 3
Re: Info please
Is BT your service provider? the answers given here will only apply to BT services, other ISPs may vary.
It would be Openreach who attend, they own and maintain the network, your best option is to see if the door company can complete the installation without causing any damage to your connection, if it does break then you would need Openreach to repair it, there could be a charge for the repair.
You could contact Openreach in advance, see If our equipment is in your way we can help.
Message 3 of 3
Re: Info please
Thanks for all the info Richie much appreciated, will pass on to my brother. Jules
