Message 1 of 3
Intercom Function on BT Premium Cordless Phone
I have a 5 handset set of BT Premium Cordless Phones.
Is there an intercom function on them so that I can talk to one of the other handsets? If there is, how do I access it?
I can't find mention in the manual.
Many thanks,
Gary
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Intercom Function on BT Premium Cordless Phone
Not documented in the manual but seems inconceivable it would be missing from the top of the range product. Try pressing the contacts button & then the volume/cursor up. That brings up the handsets on my 8500.
Message 3 of 3
Bingo! Thanks pal - that was exactly it!
