Message 1 of 2
Landline
Hi do I still need a landline now I've gone digital because I'm still being charged for it?? thanks 🙂
1 REPLY 1
Message 2 of 2
Re: Landline
I suspect you don’t really appreciate how these things ‘work’ not having a phone service doesn’t mean you don’t need to pay for a landline , as it’s  still delivering your broadband service ….if you actually mean do you need a telephone service and do you need to pay for it , no one with BT needs to have a phone service with BT anymore.
If you don’t want a phone , you don’t need to take it , the saving is around £3 a month (that’s the value of a phone service without any included calls ) .
Because in the past a landline primarily delivered a phone service and the add on service was broadband some still think remove the ‘landline’  removes the ‘line rental’ but if you give it a even a moments thought , if you don’t have a ‘line’ how do you think broadband gets to your home …all that happened is broadband is the reason to have a ‘line’ and telephone is the optional add one , rather than the way it was , phone the main reason , broadband the add on
