Message 11 of 15
Re: “Lifeline” emergency lanyard not working with Digital voice
Oh thanks. BT told me there wasn’t any other option! Much appreciated @Keith_Beddoe
Message 12 of 15
Guess only issue with that is it won’t work in a power cut?
Message 13 of 15
Neither would the home hub socket, as you would have no power on it.
How often do you get power cuts these days, and surely that is the responsibility of the utility provider?
The pendant base unit would also lose power.
Message 14 of 15
@Keith_Beddoe
Most pendent units have a battery backup built in.
The recommendation to plug into the smart hub 2 is so when you also use a battery backup or UPS to power the smart hub 2 the communication can still be achieved to the alarm receiving centre.
However, as I stated in my original reply the industry association recommends also having a fallback such as using mobile network too.
Message 15 of 15
We have a power back up for the hub & the lifeline does have a power backup built in.
power cuts can be 1-3 day on bad days but most of the time it’s that number a month….
