Message 1 of 15
“Lifeline” emergency lanyard not working with Digital voice
Hi,
My housebound mum’s installation has been fraught with problems. One that is still outstanding is that her lifeline won’t dial out.
The council who provide the lifeline stated “We have been assured that the current Lifelines we are using will still work with the new digital network as it attaches to the hub.  The only issue is that there will not be a battery back-up but you can obtain these from your provider. ”
Do these devices have to plug straight into the back of the hub? My mother’s in another room and moving it to the room where the hub is would be far from ideal.
Any advise on these would be gratefully received.
14 REPLIES 14
Message 2 of 15
Re: “Lifeline” emergency lanyard not working with Digital voice
Yes the lifeline unit would need to be plugged into the phone port (ATA port) on back of smart hub 2 in order for the lifeline to be able to dial out and connect over the digital landline service.
I would however urge the council to upgrade the unit to communicate over IP and also fallback to the mobile network as per recommendation by the technology enabled care industry association, the TSA:
https://www.tsa-voice.org.uk/campaigns/digital-shift/
Message 3 of 15
Thanks for this @@jac_95
The hub is at the far end of the property whereas the lifeline is currently in the middle. Even being in the middle it doesn't work at the extremities.
I don't suppose anyone is aware of a way of extending its range? By moving it to the hub, my mum's main living area and kitchen won't be covered....
Message 4 of 15
You could try a DIY solution and wire the internal extension phone sockets to the ATA port on the back of the smart hub 2 or use an extension phone cable.
Alternatively but not sure how well it would work is try using the BT Digital Voice adaptor
Anonymous
Not applicable
Message 5 of 15
You could try a DVA which is a DECT adapter that plugs into a mains socket & the alarm would then plug into that. That would then communicate directly with the Hub. Only way to find out if it works would be to try it. Hopefully BT will supply one FOC given your Mum is vulnerable but if not, they're around £15. If you bought one online you should be bale to return it if it doesn't work.
https://shop.bt.com/products/bt-digital-voice-adapter-100121-GN1T.html
The Hub can be relocated by running an ethernet cable to where you want it. An electrician could probably do that but no idea what they'd charge. You'd need to ring around locally. Maybe the Council would do it?
It's also possible to connect the Hub directly to extension wiring if it's already in place both at the Hub & where you want the alarm.
Message 6 of 15
Also to note if you do go down the digital voice adaptor route and you have a battery backup unit or UPS for the smart hub 2 (and ONT if applicable)  the digital voice adaptor won't be able to work in a powercut unless you provide a backup power supply for that too.
Message 7 of 15
@jac_95 which port would it need to be plugged into please? I suspect you're going to say the one her phones are in 😞
Message 8 of 15
@sallypoo
You would need one of these.
This allows both the phone and lanyard base unit to be plugged in together.
Message 9 of 15
Thanks @Keith_Beddoe . That’s a good idea.
I’ve unplugged the old phones for now & plugged in the lifeline. As I suspected it doesn’t pick up the signal from the lanyard on mum’s living room but is at least now working-confirmed with a test call from the base unit.
Now to fathom if there is a way of it picking up the signal when she’s not at the far end of the house!
Message 10 of 15
Did you read the bit about the Digital Voice Adapter, as that can be positioned elsewhere, and links back to the home hub base station? The lanyard base unit can plug into that.
BT should be able to send one free of charge.
