Message 41 of 54
Re: Phone often engaged: BT say it's due to slow upload speed?
YES
Message 42 of 54
Oh, I’m so going to miss threads like this when I move next week…
Anyway, just for the record, I was moved to DV two years ago.  I run a Panasonic quad cordless system…through the old extension, disconnected from the master socket and connected to the Smart Hub 2…it works perfectly.  So, it can be done.
A lot of the guys on here are retired Telecoms, so they can judge better than me.  I suspect you have a short in your extensions somewhere and, as extensions are the customer's responsibility, the EE tech won't touch them.  He'll just fob you off with an excuse to get out of there.   A thought does occur though, are the extensions connected to the Smart Hub and the master socket at the same time?  I can see that causing problems sooner or later.
What I will add is that most of the “guides” on the phone are not and never have been field operatives and their technical knowledge is abysmal.  They’re more sales people today.  As a retired IT tech, I find talking to them on the phone even more entertaining than threads like this.
Message 43 of 54
Glad I'm providing amusement if not enlightenment. Only the cordless phone is plugged into the Smart Hub as I keep telling everyone.
Message 44 of 54
From message 10
We tried ringing ourselves and it rang on the extension, but on replacing the phone and lifting up receiver we're now engaged
Message 45 of 54
Sorry, not entertainment as such, just a bit more intellectually stimulating than the forum for the ISP I’m moving to.  Anyway, you might find this interesting…
https://community.bt.com/t5/Home-phone-including-Digital/Digital-voice-line-constant-engaged-tone/m-...
This one's worth a read too...
https://community.bt.com/t5/Home-phone-including-Digital/Digital-voice-permanent-engaged-tone/td-p/2...
Message 46 of 54
Is this the Final Solution? Currently the wire that feeds the two extensions goes into the master socket. I intend taking this out, crimping on a BT 431A plug then inserting into the back of the router green socket via a twin splitter together with a cordless phone that's above the router. Everyone happy, ecstatic even?
Message 47 of 54
Yes, that will work.
Delirious
Message 48 of 54
Glad I've achieved summat today.
Message 49 of 54
Please post back and confirm you made the changes and what the forum members have been posting since outset has worked and your extensions are working as before
Message 50 of 54
I will once I get the BT plugs off eBay.
