Message 1 of 7
Motorola FW500 backup phone
When my elderly parents converted to Digital phone over existing DSL broadband BT installed a Motorola FW 500 backup phone and told them to use this phone in an a emergency only.
I have read this phone can be used when the power is on and you should get 2 dials tones, one when the power is on ( phone over BB) and different dial tone if the power is off indicating the calls are now going over the SIM.
Currently I don't get dial tone when the power is on. Anyone have one of these?
Thx
Scouser
6 REPLIES 6
Message 2 of 7
Re: Motorola FW500 backup phone
Update, when I say "power is off or on" its probably more correct to say BB is on or off.
Message 3 of 7
Hi @99scouser
Do you have a SIM card inserted in the telephone?
You can visit EMERGENCY BACK-UP LINE TELELPHONE MODEL: FW500 Manual on how to check this.
Ali
Message 4 of 7
Yes, BT installed the phone and sim last week when they cut over to digital phone service.
Message 5 of 7
@99scouser
Although there is no dial tone, are you able to make an outgoing call or does it ring with incoming calls?
Ali
Message 6 of 7
Hi ALi, no,  no incoming calls and no dial tone. The screen is lit up though.
Message 7 of 7
@99scouser
Although you have no dial tone, are you able to make a call?
Please check all cables are correctly connected between the phone and router.
Ali
