Message 11 of 14
Re: Moving broadband with Digital Voice from BT to EE warning
Hey there @wilsonmfw.
If you  head over to your Hub manager on http://192.168.1.254/ and select your landline number, it should give you the option to export your contact data, as well as import contact data from elsewhere.
You can then save that to your PC for if you ever need to change Hubs.
Peter
Message 12 of 14
Thank you Peter, sorted 🙏
Message 13 of 14
Greetings,
Regarding moving from Plusnet (BT) to EE Digital Voice, from what I read, there are few good points.
But before I make a decision ( I already have a SIP account - have done for years! )
I would like to ask - what are the costs involved in EE Digital Voice ?
Regards - another old fogie 🙂
Message 14 of 14
This is a BT forum, you need to ask that on the EE forum.
https://community.ee.co.uk/
