Message 1 of 6
My landline has started withholding numbers - starting with my mobile so I cannot ring home
I need to stop my landline from withholding my mobile number plus others.  It
5 REPLIES 5
Message 2 of 6
Re: My landline has started withholding numbers - starting with my mobile so I cannot ring home
by withholding do you mean blocking your mobile number?  does it do likewise to  other mobile numbers ?  what about landline numbers?  what have you tried to solve problem? checked MYBT phone in case numbers blocked by mistake?  are you on digital voice?
Message 3 of 6
How do I check MYBT?
Message 4 of 6
you can log in to MYBT using link at top of page then check your phone and blocked settings
Message 5 of 6
It says it allows my number but no, it says ‘withheld’ how do I stop it?
Message 6 of 6
@deehillsp
What message do you hear when you are trying to ring home from your mobile?
Ali
