Message 11 of 13
Re: Not Received New Hub for Digital Voice
I did think it a bit odd, as the switch is instigated once a valid registration is seen from a hub. This process has been mentioned before on this forum.
Message 12 of 13
Ah, I hadn't found that, although admittedly I'd started from the point that my problem was non-delivery of the new Smart Hub (I did go through the FAQ, and the stuff on the BT Website).
Message 13 of 13
If you think about it, the phone number can only have one presentation, either on the PSTN line card in the exchange, or the Smart Hub 2 via the DV platform.
The changeover would be handled robotically, but there is a lot of things that can go wrong, especially where incoming calls are concerned, as confirmed by many post on this forum.
