Message 1 of 5
On a BT 4600, in the settings there is an option for "First ring" to be on/off, what is First ring?
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: On a BT 4600, in the settings there is an option for "First ring" to be on/off, what i
From another model:
Message 3 of 5
Thank you very much, I couldn't find that anywhere, is there a document that explains what each setting actually can do please.
Anonymous
Not applicable
Message 4 of 5
Only the manual that you already have. No idea why it isn't explained. Other than that it's down to Google.
Message 5 of 5
Thanks, even Google don't know sometimes.
