Message 1 of 3
Openreach possible solution to vulnerable & phone 0nly customers
this is posted today and may be a solution for vulnerable existing customers to retain their existing phone line
https://www.ispreview.co.uk/index.php/2023/11/openreach-prep-alternative-uk-analogue-style-phone-pro...
2 REPLIES 2
Message 2 of 3
Re: Openreach possible solution to vulnerable & phone 0nly customers
Interesting....Only glanced over this myself, but doesn't this amount to an open-ended commitment to maintain the copper network, even though it's falling apart?  I though the idea was to eventually retire that.  I may have missed something but it seems an odd change in direction.
Message 3 of 3
Its not clear exactly what form this will take , but it’s not likely to include keeping the exchange switch estate working ( System X and System Y )  past December 2025 , the copper pair network has never part of the WLR/PSTN removal program , although it is in its retirement period,  it will  remain for some users  , for many years to come.
Presumably the intention of this product is to remove the need for any customer provided power supply for their basic telephone equipment , mimicking  the current ‘exchange’ 50V DC power supply  , and AC 90V  ‘ringing’ current ,delivered from the exchange ‘line card’ , a member of a different forum speculated that  this ‘service’ could in effect be an ATA ( analogue  telephone adapter ) equipment located at the exchange instead of at the customer , so basically it is still IP telephony ( allowing the exchange switch to be retired ) , but all the equipment normally at the customer end for IP telephony  is located at the exchange ( the exchange buildings are not disappearing in December 2025 ) the copper pair to the customer ( via the ATA ) keeps  the 50v present on the copper  pair to the customer address , meaning at the customer end , nothing changes.
This  makes the recovery of E side cable’s complicated ( but so does SoTAP ) but does allow the exchange equipment to be switched off,  ‘telephony only lines’ that have no local power  can be maintained.
