Message 1 of 4
Registering a BT Advanced Digital Home Phone
Although I have no intention whatsoever of using it for calls, I bought it just to see what it looked like in comparison to the photos of it & I've found out, via another thread, that it can be used to switch off the multiple call function which I will do.
I've attempted to register it tonight with no success despite reactivating the hub's WiFi.
Is my assumption that the SSID & password have to be the same as the hub's original SSID & password before I changed them when I installed the mesh system correct?
3 REPLIES 3
Message 2 of 4
Re: Registering a BT Advanced Digital Home Phone
It requires the BT Smart Hub 2 and connects via the Hub's built in DECT receiver rather than WiFi.
You can check the status of it's connected to the DECT receiver via the Hub's web gui (http://192.168.1.254)
https://www.bt.com/help/landline/digital-voice--how-do-i-set-up-my-service-
Message 3 of 4
Do you have an active digital voice required for registering the phone
Message 4 of 4
@jac_95  & @imjolly
Thanks for your replies.
Yes, it's a Hub 2 & I have Digital Voice with my package.
I reset the hub & disconnected the mesh system & it registered immediately but as you say, its  DECT so maybe it was a fluke that it didn't register the first few times.
Anyway I've changed the line to single call & disabled call transfer as there's only me in the house.
The phone can now go back in it's box, never to see the light of day again.
