Message 1 of 16
Phasing out landline phones
Hi,
I have a major concern that apparently BT will be phasing out traditional landline phones by the end of 2025, and customers phones will be supplied by broadband.
My concern is my elderly parents don't have broadband but their landline phone is their lifeline.
The issue I have with this is if there is an electricity power cut there will be no broadband as broadband requires a router, and routers are supplied by electricity.
Plus will customers lose area codes, or numbers that the properties might have had for generations.
Personally I can see no end of misery from phasing out landline phones. And I would like to know how is this all going to work.
15 REPLIES 15
Message 2 of 16
Re: Phasing out landline phones
@Roadhawks
Welcome to this user forum for BT Retail phone and broadband customers.
Openreach do have a proposed solution for this.
https://www.ispreview.co.uk/index.php/2023/11/openreach-prep-alternative-uk-analogue-style-phone-pro...
Message 3 of 16
On the Openreach network there have been 3 ways to provide a voice service:
FVA (Fibre Voice Access) - This has already been phased out.
PSTN (Public Switched Telephone Network) - The most common and the service being discontinued with the switch off prediced by 2025
DV (Digital Voice) - The new all IP way of providing the service, it rerquires a broadband connection
Regardless of what way you recieve the phone service, the price is the same and nobody is being charged anything more, if your parents don't have broadband, a slower broadband SLT (service line type) has been created which is more than adequate to provide a phone service.
As previously mentioned, your parents will be supplied a Smart Hub and broadband package that supports their needs, at no extra cost.
Alternative ways are also possible, such as providing the service over the mobile network, still using the same landline telephone number.
The same could be said now if the exchange lost power, the network requires electricity so if any part fails, it would stop working for the end user.
BT do have battery backup units, there is a cost but vulnerable customers are supplied free of charge or alternative solutions are available such as a handset that uses the mobile network if the service fails, BT do not provide electricity supply and have no control over the reliability, there are however priority repair services for vulnerable customers, you're parents would need to speak with their supplier to see what support is available.
No they won't, infact the new Digital Voice removes the exchange limits, previously the numbers are tied to an exchange, if you moved home that was served by another exchange, you lost the number and were issued a new one, now you can retain the same number if you move to another area.
Moving to Digital Voice will see customers retain the same number, the technology providing the service is changing but the number you have remains the same, the cost remains the same, you can use the same handsets you previously used.
Several million customers have already been migrated to Digital Voice, all new provisions are done using Digital Voice, yes things can go wrong but not more than issues from the previous methods of providing a telephone service.
It's worth noting that BT's Digital Voice is not new technology, Europe have used this method for years, we're just late adopters to the technology, the old analogue copper PSTN network is old and outdated, it's expensive to run and maintain, so Openreach decided way back in 2015 that it was being switched off, the industry has had almost a decade to prepare for this, so alarm companies and other services that use the phone network can be ready.
When BT do migrate customers, a process exists that a friend or family member can be given the update on the switch and any other support needed when the migration comes, your parents can choose you for the updates so you can see key dates and any steps needed when the switch comes.
I would also advise looking at www.bt.com/hereforyou to see what other help and support BT can offer your parents, there will be things not needed at this time, it's still useful to know for future reference.
I hope that helps and answers your concerns, reply back with any questions 🙂
Message 4 of 16
Thanks for your help.
So in a nutshell with the new changes and if the property lost electricity, there would be no phone?
Whereas now if theres a powercut they can still use their phone.
If thats the case it will leave lots of people without vital communication.
Message 5 of 16
many people of the older generation are quite capable of using mobile phone which could be used in an emergency.  mobile phones will connect to any network if using for emergency numbers
as one of the older generation it is very annoying when people post assuming that we are incapable of using mobile phones
Message 6 of 16
@Roadhawks
Many people now use Digital Cordless Phones and have done for years. They’re often given to elderly parents by their children so they don’t have to leap out of the chair when the phone rings and to keep in touch. These phones also need electricity to function and I don’t remember there being much of a concern about them if there was a power cut.
Message 7 of 16
@Roadhawks The subject has been done to death on the forum. It's going to happen, just as the analogue TV switch off happened.
Anonymous
Not applicable
Message 8 of 16
@-Richie-wrote:
"The same could be said now if the exchange lost power, the network requires electricity so if any part fails, it would stop working for the end user."
Except that the current exchanges have backup batteries and generators. In the exchanges that I worked in many years ago, the fuel tanks were capable of storing enough to run the exchange for many days, weeks even, without mains electricity - and were kept near full.
These buildings were mostly built and specc'd in the 1950's - during the Cold War.
Message 9 of 16
Whilst that was the case for larger exchanges, many small rural exchanges don't have generators.
Message 10 of 16
I had a fault several years back, my exchange had no backup generator, I was without phone and broadband for several days, I had power in my home because the power cut wasn't impacting my street.
I have given you several options regarding power cuts, the switch off is going ahead because Openreach have made the decison and announced it almost 10 years ago, alternative solutions exist
