Message 1 of 2
Phone not ringing
My dad’s home phone (set up for digital voice) has started ringing once and then going straight to voicemail. It started doing it when I was abroad and my dad swears he’s done nothing to it. I’ve checked and apparently there is no call forwarding or divert turned on - has anyone experienced anything similar? I’ve gone through troubleshooting and line checks, but apparently no issues
Tags (2)
1 REPLY 1
Message 2 of 2
Re: Phone not ringing
Hi @Cathsta25
Sorry to hear you're dad's having an issue with the phone rings.
If all settings have been checked, it may be a technical fault with the router.
There are a few things to check -
Which handset make/model are you using for the landline phone? It may be a sudden compatibility issue.
Do you have access to a wired-handset that you could test in the back of the router?
Have you tried a full reset of the router hub?
If those steps and our Fix A Problem | Landline | BT  page don't resolve your issue you'll need to call Customer Service who can diagnose the hub and replace if needed.
Ali
