Message 1 of 3
Phone
Hello can some one tell me if i need to pay for a landline if I get a digital phone as am now paying landline rental up front for a year and it ends soon don't use phone a lot as an old age pensioner, and what will it cost to make phone calls on a digital phone
2 REPLIES 2
Message 2 of 3
Re: Phone
You are not paying for 'landline' rental you are paying for 'line' rental which is itself a misnomer as all broadband packages include line rental rather than as a separate item and have done for a number of years. BT are finally ceasing the availability of Line Rental Saver.
Broadband still requires a physical line.
You can have broadband without telephony but the saving is only approximately £5/m
Message 3 of 3
Re: Phone
If you want a broadband only package without a landline telephone you just order a broadband only package.
If you want the ability to make telephone calls you would need to order a broadband and landline telephone package then select a calling plan that meets your needs.
By the sound of it you would be best with a Pay as You Go calling plan which means that you only pay for any calls that you actually make rather than having/paying for an allowance of call minutes which you might or might not use.
See link for calling plan costs.
 What are the BT Calling Plans and how can I change to a new one? | BT Help
