Message 1 of 4
Porting BT landline to a VoIP
Hi,
We're currently on Fibre2 with a copper landline - this was being kept because of the need for a fall-alarm box.
The box has now been switched to a sim-based connection, and we are out of contract with BT.
We need to keep the landline number, it's the number my elderly mum has had for decades, and she never got on with mobiles.
Trying to economise on costs, and not wanting to risk losing the landline number, I was hoping to port the number to a VoIP service to separate it from the broadband service.
Any advice on the best way to do this, while keeping the BT broadband service ongoing but preferably without starting a new BT broadband contract - at least not until the number has been ported, because I'm assuming a new broadband contract would tie the landline number to BT for another 24 months?
Been a BT customer for years, don't want to leave but don't want to be handcuffed either - not without a safe word 🙂
Thanks for reading,
3 REPLIES 3
Message 2 of 4
Re: Porting BT landline to a VoIP
You need to Port the landline number to your VOIP provider first which will end your current BT phone and broadband contract and then decide if you want a broadband only contract with BT or another ISP
Message 3 of 4
Thanks. So, the action would be to port the number to VOIP - which ends the BT broadband, so have a backup such as a data sim using another device as a hotspot until the new broadband service kicks in.
Message 4 of 4
Yes Voipfone who charge me £6 a month (for up to 100 minutes of calls) took my order to port the landline and then they notify BT  of the porting  and specifically say you don't contact BT to avoid confusion. BT then automatically cancelled my broadband and landline  within about a week (faster than I thought without problems - I had to buy a bit of kit from Voipfone , a one off charge). On the day of telephone number moving over to them BT did indeed shut off my broadband and landline.
(I had also by then separately installed a different broadband provider (Community Fibre) so had that one and BT BB running side by side until porting day which is more expensive than most people want but saved my worries over the number porting. The ported number with Voipfone runs over the Community Fibre broadband FTTP line).
