Message 1 of 9
Problem with adding a number to BT Call Protect
I first tried to use the dial 1572 option, which proved to be completely useless.  I was told my Call Protect list was turned on but NOT how to add a number to the list.  So I then tried the My BT route, which in theory was very straightforward.  But I was unable to access the Call Protect page because my account number was not recognised. The My BT home page turned out to have two different numbers listed for me, albeit that one of them was marked "Inactive".  So I then checked what was the account number listed on my most recent phone bill.  And that proved to be identical to the Inactive one.  However, I then found that the BT system did not recognise EITHER of the two numbers it had listed for me on My BT.  So I am now completely stumped.
Can anyone advise me on how to resolve this, please?  I have wasted so much time already.
8 REPLIES 8
Message 2 of 9
Re: Problem with adding a number to BT Call Protect
try contacting billing using message now and they should be able to help
https://www.bt.com/help/contact-bt/account-and-billing/broadband
Anonymous
Not applicable
Message 3 of 9
Hello I use Call Protect 1572. You can't "add" a number to the list. You have to answer the phone, when the number you want to block has called, and then call 1572 straight after followed by pressing 1 to add the last number answered to the block list .
Hope this helps 😃
Message 4 of 9
A complete waste of time. The numbers are spoofed and the scammers have an infinite amount of numbers to choose from, they don't use the same number every time.
Blacklisting is pointless, the only way to prevent scam calls is whitelisting.
Message 5 of 9
Thanks for this.  But it doesn't help in my particular circumstances (won't try to explain why).  Also, I have to say, this seems to be a ludicrously restrictive way of using Dial 1572.  WHY can't one simply add a number?
Message 6 of 9
I hear what you say.  But it's not actually a scam call that I am trying to stop.  It's an automated reminder call about an event that the event organiser has proved unable to turn off.  And I'm sick of being rung at 7.00 am day after day.  Then the calls repeat several times.
Anonymous
Not applicable
Message 7 of 9
Tomorrow morning at 7 when they call just add it to call protect as you would any other nuisance incoming call...or am I missing something?
Message 8 of 9
Thanks again. It's not that simple, for reasons I won't go into. But I have now got BT to fix the problem that stopped me using My BT before.
Message 9 of 9
Thanks mate. I have used the link to connect to the Chat line and got the problem sorted that way. Fingers crossed! It will take up to 24 hours to be sure that the fix has worked.
