Message 31 of 40
Re: Problem with digital voice landline phones.
I'm still totally confused. If you have Digital Voice phones you have no need of a Digital Voice adapter which you appear to have. The DV adapter is a device to enable analogue phones to connect to the hub at other locations than where the hub is sited.
Message 32 of 40
Yes, I think Licquorice is right.
 Part of the problem here is that we are confused about the type of phone you have.  So, is it:
  • A DV phone.  That is a cordless handset that uses the home hub as its base station, or
  • A traditional phone connected to an adapter plugged into a power socket elsewhere in the house, or
  • As I mentioned, it could also be a traditional cordless phone, using its own base station and that base station is plugged into the Home Hub?
Message 33 of 40
Or the base station plugged into an adapter.
Message 34 of 40
How on earth are elderly people supposed to cope with digital voice and all the tech that goes with it to solve issues. My mum is nearly 90 and if I didn't live nearby she would be completely out of touch with everyone. I'm so angry about it.
Message 35 of 40
My apologies for not having closed this issue I was having recently with my 2 'landline' phones.  In the end, my son solved the problem.  And, later on, BT sent an engineer to check out my house and all the broadband connections.  Somehow, I had managed to 'unpair' the phones and that was all it was!  Well, I say that, but the biggest problem I have is that my old cottage has walls!  I am now experimenting with the 'hybrid' thingy by moving it around to see if I can get a stronger signal and also one of the 'discs' to see if I can listen to on line radio in my conservatory.  Things were so much better (and much more reliable) when we just used switches.
Message 36 of 40
I don't think I saw it specified earlier, but sorry if you've already said.
If you are on Full Fibre (FTTP), instead of copper (VDSL/FTTC), the ethernet cable between the ONT on the wall and the router can be up to 100m long, so you can move the router if you want.
Message 37 of 40
Thank you, that's helpful
Message 38 of 40
"How on earth are elderly people supposed to cope with digital voice and all the tech that goes with it to solve issues. My mum is nearly 90 and if I didn't live nearby she would be completely out of touch with everyone. I'm so angry about it. "
If "elderly people" just have their analogue phone plugged into the standard wall socket then, when they are migrated to digital voice, all they have to do is unplug it from the wall socket and plug it into the green socket on the back of the hub. That's all there is to it- really not "all the tech" at all!
Message 39 of 40
And then the hub needs restarting now and again and to start with my mum has no idea about plugging the phone line in. This isn't all "elderly" I know,  but some just about manage to live on their own and can't cope with change.
Message 40 of 40
It shouldn’t need restarting once set up.  It may need a reboot once a fortnight, but it should do that itself.  Why do you say it needs restarting?
As far as your more general point goes, it’s an awkward one and I can see both sides of the argument.
The old analogue phone system is now of an age where it is starting to fall apart, and no one makes spares for the equipment anymore.  So, what do we do?  Just wait for it to stop working altogether or start updating it?
90’s admittedly is getting on, so I would have thought it appropriate for a tech to be sent out, to set it up for her.  Once set up, it should work like the old phone.  Mine was no different to the old phone once up and running.
If you’ve not already done so, it might be worth contacting BT and registering her as vulnerable.  I believe a tech would have been assigned automatically if she was already registered.  (I might be wrong on that, though).
Then again, a lot of older people do cope quite well with this.  My own mother passed at 87, but she was quite capable of pulling down recipes off the internet and sending emails etc.  Admittedly, if something needed fixing that would be my job.  But then again even I’m an OAP.  And I know young people that have more difficulty with this than mum would have done.
I think it is difficult to know what to do for the best in these situations as it varies with the individual.  I hope you get it resolved soon.
