Message 1 of 5
Problems with digital voice
since moving to digital voice I can no longer have messages recorded on my landline. Having read various threads they say it is possible to opt out of digital voice. I cannot find how to do this. If I am out or don't hear the phone I don't know if a message has been left as Digital voice does not let you know there's a message where my handset lit up to inform me of messages. Surely there has to be an easy way round this but I have failed to find it so far. Are new handsets better able to show recordings or is it just something else useful lost? I live on four floors so it is easy to miss a call and they are frequently from hospital.
4 REPLIES 4
Message 2 of 5
Re: Problems with digital voice
You could call BT and get the BT 1571  voicemail service removed, or set it yourself to the maximum number of ‘rings’ (10 I believe) before the call is sent to the BT answer service, and then change your own answer machine to answer after fewer ‘rings’  ( 5 ‘rings’ for example) that way your own machine takes the call if you don’t answer yourself , but obviously some calls  you could have potentially answered because you are at home may go to your answer machine if 5 rings doesn’t give you enough time to get to the phone and answer it in person.
Message 3 of 5
@Helenfox
There is an easy way round this as @iniltous has described and is exactly what I have done and it works.  I've set 1571 to the maximum number of rings and have my answerphone set to fewer rings before it kicks in (I think it's two fewer rings than whatever 1571 is set to).  That way, the answerphone always gets to kick in before it goes to 1571.  Simples.  🙂
Message 4 of 5
thank you so much I would never have got there without your help but now sorted.
Message 5 of 5
yes, thank you, I did the extended ring thing and it works! Wahey!!
