Message 1 of 6
RJ11 double adaptor with SH2?
Our BT Decor 'phone is plugged into our SH2 (FTTP).  I would like to energise our existing house wiring as well (currently redundant as old copper line is dead).  There is a socket close to the SH2.  Can I plug an RJ11 double adaptor into the SH2 to connect both the 'phone and the network?
5 REPLIES 5
Message 2 of 6
Re: RJ11 double adaptor with SH2?
Yes, but make sure your copper connection is not still connected to the external network.
Message 3 of 6
Many thanks for prompt response - just what I hoped to hear!
Message 4 of 6
It's a double ended BT 431 rather than RJ11 that you need.
Message 5 of 6
this explains how to connect to activate extensions
https://community.bt.com/t5/Archive-Staging/Correct-way-to-enable-all-BT-sockets-after-Digital-Voice...
Message 6 of 6
Many thanks. I searched through my rather large bag of accumulated cables and other paraphernalia and found a double-ended adaptor, so now have the Decor 'phone and network all connected - very simple for a non-techy person like me. I'll convert the redundant master socket to a flush-mounted socket to look tidier.
