Message 1 of 2
Re: BT answer machine doesnt work with Digital
My answer machine will not take calls with digital. It says speak after the tone but nothing records
1 REPLY 1
Message 2 of 2
Are you sure it's your answering machine answering the call and not 1571?
If it is your answering machine answering, the problem is with that rather than DV.
