Message 11 of 11
Re: Keeping existing number when switching to digital voice (OFCOM)
@Basil-Brush
if you have a lot of contacts on phone then I would export the contacts file to a safe place as a factory reset of hub will delete all your contacts and you will be back to square one.  if you have the file you can import it and get contacts back without much effort
