Message 1 of 7
Removal of bt cables
hello. I am going around in circles.
I tried calling bt open reach option 1. Was told I needed to use live chat to request removal of bt cables from outside. The main one from the pole has pulled our sophets and letting rain in which has started to cause damp in front bedroom right underneath.
I tried live chat. Said get with me with in 5 mins. I waited an hour. Tried again another hour. Rang back same number to be told to email them. They said I would find their email on this site. I can't for the life of me find the email?
We are with virgin broadband and phone. Have been for 20 years. So no need for bt wires and cables.
Any advice please?
Many thanks
6 REPLIES 6
Message 2 of 7
Re: Removal of bt cables
@Darlyd
This is a BT Retail Customer Forum, and has no connection with Openreach.
Try here https://www.openreach.com/help-and-support/damage-health-and-safety
Message 3 of 7
Hi @Darlyd and welcome.
Thanks for posting. Sorry you're having problems getting the old cabling removed. You can use the contact us link in Changing our existing network | Openreach and Openreach will get back to you within 5 working days.
Cheers
David
Message 4 of 7
Thank you but that's the number I've rang.
Message 5 of 7
Thank you. Form isn't going anywhere as I am not a customer. And don't have a telephone number or customer number.
Message 6 of 7
as the cabling is property of openreach and No Bt Retail there is nothing this BT retail community forum can do to help you.  you need to contact openreach
Message 7 of 7
You should be able to report it to Openreach as a safety issue, if its likely to fall down and injure someone.
