Message 11 of 11
Re: Removing an external cable
I suspect it was wired by someone who does not understand Telecom wiring and what the requirements are. They would be individual wires terminated.. Basically multiple wires make up a cable.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
