Message 1 of 7
Replacement Bt 8600
Are Bt 8600 additional handsets still available or are the new ranges compatible .Looking at full fibre upgrade which will mean siting main base next to relocated next to router
thanks in advance
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Replacement Bt 8600
They're discontinued so you'll probably need to look at used from Ebay/Facebook Marketplace/etc.
But if you only require this because of relocation of the base, you could look to just buy a charging base to move the current base handset where you want it. Or if disciplined enough, just return the handset to the base station for charging overnight.
Message 3 of 7
Thanks for the response best solution would be to look for additional base and phone so on the internet I shall travel 👍
Message 4 of 7
Deleted by poster.
Message 5 of 7
I have looked at the phone you mentioned
Message 6 of 7
@Skirk1
I mentioned the BT4600, but I deleted the post as I assumes you will going to look for anyone with spare BT8600 parts.
The BT4600 is quite popular, and works well here.
Message 7 of 7
