Message 1 of 15
Retrieve inactive phonenumber
14 REPLIES 14
Message 2 of 15
Re: Old landline number retrieval
I have had a similar problem, I changed provider, they changed broadband but sent my phone number to a different provider, they said they no longer do phones, I cancelled the order but they did not retrieve my number, when I went back to my original provider, they gave me a start date for the service, phone and broadband, it did not happen the order had been cancelled. I placed another order that did not happen. The number porting needs to know the last owner or provider of the phone number. If it exceeds 28 days the number becomes inactive. That is where I am now trying to retrieve an inactive number.  There are two other time frames 60 days and 90 days after which it could go into a pool and be available for anyone.
Message 3 of 15
You are posting on a three year old thread.
If you have a question, starting a new thread would help as people are not likely to wade through a three year old thread to find out what is going on.
Message 4 of 15
are you a BT customer? broadband and phone?
Message 5 of 15
Activate a land line number
How do I activate a number that has become inactive.
Message 6 of 15
Re: Activate a land line number
@Pedra
please stop posting same question over and over it just leads to confusion and won't help get answer faster
Message 7 of 15
You can't. You would need to contact BT 0330.1234.150, if it is a BT number, and ask if it is available and if you can change your present BT Landline number to that number.
Message 8 of 15
I have found out my old number has been moved from inactive to pool and should be available to port to an existing line, fingers crossed, find out after bank holiday
Message 9 of 15
I have tried contacting BT they say that it is up to my present supplier to follow BT procedure to recover my old number that is in the phone book. It is now two months since Openreach disconnected my phone without any orders in the system, I was not notified where it had been assigned. BT do not specify the procedure.
Message 10 of 15
They say it is in the POOL and is available, is there a procedure to acquire my number by a provider other than BT
