Message 1 of 2
Running two hubs ?
I’m running a Linksys router and mesh network, plugged directly into the OR wall box.
I’ve been told the system is moving to digital voice and been sent a SH2 and Voice phones.
I understand that the phone will only work with the SH2
My question is, can I connect the SH2 to a second port on the wall box and use the hub only for calls ? I have connected it but get orange light, can’t seem to connect the phone to it. Am I trying to do something that just will not work ?
1 REPLY 1
Message 2 of 2
Re: Running two hubs ?
You cannot plug the Smarthub 2 into a second port as you have suggested.
If you want to have Digital Voice, the Smarthub has to be the first device after the digital modem.
See the following thread for all the information that you will need.
Full Fibre To The Property with Digital Voice and ... - BT Community
